40 hub rubber ring
Finger Lakes region ny
doing a total nut and bolt restoration on my 79 40 I drove off the lot in 80. Currently in the birfields. When disassembling the hub there was a rubber ring on the side that the brake I found after I removed the rotor. After everything was cleaned and painted and upon installing new OEM rotor it doesn't fit between the two. Can't figure out where it should go. Any help?
