Build "40-DAZE" 66' FJ40 build (GOIN' 4 BROKE !)
  • Thread starter Thread starter MT TUBEKRAFTER
  • Start date Start date
M
MT TUBEKRAFTER
Guest
Hey everyone,
I have been asked to do a build thread here , of my 66 fj40 build up. I am not sure if it should be in this "section" or "Hardcore" so here we go....
FIRST A LITTLE HISTORY....... FINALLY.... after years of wanting and searching for a 40 I stumbled across an ad for one in our local classifieds....66 landcruiser ,new GM 350 , soft-top ,hard-top ,winch ,new 33" tires and wheels,new brakes w/new wheel cylinders....$2,800..obo
so I presented the ad to the wife...threw down my best puppy eyes and said I gots to buy this....wife says call and go look at it , the ad was several days old ,figured it was probably gone by now
I called and it was still available....so away we went...(middle of winter 10*)we pull up and there it is in the middle of a field running "purrin' like a kitten" got out did a quick walk-around ...I hate the cold!!! . It was what the ad had stated...long story short offered him 2,400 and he took it.....WHOOO HOOOO !!
I didnt even drive the thing...I've wanted one for a long time and this seemed like a great deal.....anyway this was 2 years ago....havent had much time to work on it since purchasing it the whole thing was covered in bed liner crap ..and I mean EVERYTHING !! So thats where I started ...had to remove that s***E !!! was not fun but got it done...anyway heres some pics of when I got it and what I have to work with.....
HERES THE PLAN ...retain all running gear for now ,link- it FRONT and REAR ,want to keep full bodied look ,possibly dove tail rear,add cage,bumpers,blah ,blah, blah, just want to make trail worthy for now ...MODIFY as needed . so here it is ...WHAT WOULD YOU DO WITH THIS 40.....? (keeping the budget as low as possible)
I painted what was bare with some "Aervoe" protective paint, and then began to layout some tube work.
I bent up some tube for "lower body protection" ,"tube fenders",and some rollcage pieces.
Then I cut the fenders off leaving the inner fenderwell's in place
a few more pics ...
LOT'S OF CLEAN-UP TO DO AT THIS POINT.......cleaned up front and rear housings
I also decided I will be "linking" the front and rear, so I built some "axle truss / upper link mount" attachment point's...
Once I got the "stock housings" cleaned up, I scored a set of FJ 60 housings from my nieghbor !! :bang: and quickly began the housing cleaning process "again"
Since I will be gaining more track width, front disc brakes,and bigger pinion I felt the setback was worth it :grinpimp:!!!
There was quite a few more things to cut off the fj60 housings , as they were loaded with all the latest goodies, swaybars etc.
I also lucked out because the truss's I built fit them with minimal trimming, due to different slope where the tube transistion's to the the third member section :D
Nice, what size are the two different sets of tires. Love the snow pics.
235/85/16 and 38.5/14.50/15 I like the snow pics too, just dont think I'm ready for winter again,already...it snowed in the hills just above us last night !!:rolleyes:
Then it was out with the "old axle" and in with the new!!:D
I will be using an fj80 steering box, allowing me to move it further back on the frame and out of harms way ,unlike the saginaw set up !!;)
Then I proceed'd to clean the frame up and remove all unneccesary brackets..
These are for sale ,if any one needs them ;p
Suspension parts ...
The rear coil springs are OME 3.5" front springs and buckets from an fj80
The front springs are a 3.5" Fabtech progressive rate coil off of my 98 Tacoma IFS lift combined with some home brew ingenuity, more on that later...:D
For my "upper links" I ordered up some 2" .250 wall DOM (12')
For my "lower links" I went with some 2.25" .375 wall DOM (12')
For the "Joints" I chose Ballistic's 2.63 forged joints W/1.25 shank, I also ordered some of their forged joints W/poly bushings, I ordered 8 of each along with the appropriate tube adapters, jam nuts and their handy tool for rebuilding and adjusting the joints.
I also tried saving myself some time and ordered some brackets since they were having a sale.
