Need help on how to run brake lines on 69 fj 40 with 83 mini truck fronts, and monte carlo rears. porportioning valve or not??? Does the front fitting on the master cylinder supply ONLY the front brakes? and the rear fitting to the rear?? Should i run all new 3/16" brake lines? No parts store seems to have the right size brake line fittings to adapt to.Do i need to remove a spring from the master cylinder ( i,ve heard rumors)?? Any help is appreciated.
