4 wheel brake conversion
Williamstown, NJ
Website
www.fj40taz.com
I converted my 74 to 4 wheel disk brakes. Used the front axle from a 78 and the monte carlo rear calipers with a brackets from someone here on the forum.
I used an fjz80 master cylinder and a chevy brake booster.
my issue is I seem to have a really hard brake pedal. The vehicle does stop but the brake pedal is super stiff. I did take a little off of the internal shaft as the rear brakes were dragging allot at first.
also have a propositioning valve in place. I cannot remember the brand but it might be a wilwood.
OK..I thought I was the only one with this problem. I too used the monte carlo calipers and brackets. I went a step further and used a hydroboost with a GM master and proportioning valve on the rear. Pedal is soooo hard its like the hydroboost isn't helping at all.
I used an FJ60 master cylinder, OEM toyota brake booster out of an early Toyota pickup, and the wilwood adjustable proportioning valve, along with the monte calipers and brackets in the rear, and FJ60 outer axles up from. Stops perfectly. Seems to me it's likely something to do with the GM booster setups - as this seems to be the common links between the hard-pedal setups described above.
do you happen to have a part number or year of the truck you got the booster out of.
