4 speed trans
Homewood(B'ham), AL
Now I know your thinking another trany post but ive searched and I just cant figure anything out.
Note: this may not happen for a while, my dad wants 4 on the floor and so Im researching it for him. That said...
Im thinking of replacing the stock 3 speed trans in my 71 fj40 with the 4speed from MAF which says
These are good, used, non-USA, Land Cruiser 4 speed transmissions that feature a 4.925:1 first gear ratio for those that want lower gearing without spending a small fortune. If coupled to an early transfer case designed for use with an OEM three speed transmission, the resulting gearing for off-roading is truly awe-inspiring, and best of all, it's a factory Land Cruiser part, no adapters to fit to a Land Cruiser transfer case. Uses OEM 4 speed bell housing, clutch assembly, clutch fork, throw out bearing, slave cylinder, pilot bearing, shift lever, shift boot, etc. (you get the point), and costs less than a SM420/465 adapter kit.
Now it sounds like this can couple with a 3speed tcase with out any extra crap. Does anyone know if thats right? And does anyone know how much that other stuff costs or where to find it? Will I have to change my d-shafts? Will the 4speed clutch kit from cruiserparts.net contain any of this stuff?
You will need to install this kit in the 3 speed t-case:
090-05 Transfer Case conversion kit. These are the parts necessary to get a transfer case from a 1973 and older FJ with the 2.31 low range to mate up to the 1974 thru 1980 4 speed transmission with the 16 spline tailshaft. Included in the kit are a brand new adapter gear, pto spacer sleeve, new imput bearing and seal. This is a web-only special. $139.99
as found here (11 items down):
http://www.marksoffroad.net/specials/Specials.html
or find someone to swap your 3 speed case to for a 4 speed then you will not need the kit.
kls
I know about a conversion gear, Am I reading the description wrong or does it say that it will fit on a 3spd tcase without an adapter?
[If coupled to an early transfer case designed for use with an OEM three speed transmission, the resulting gearing for off-roading is truly awe-inspiring, and best of all, it's a factory Land Cruiser part, no adapters to fit to a Land Cruiser transfer case]
you will also need a 4spd bell housing and d shafts maybey 2 flanges for the diffs then it should all basicly bolt up good luck
The language is confusing in the MAF add but the down and dirty is its a 4 speed tranny and therefore will have a 16 spline output. The 3 speed case will need to be adapted.
kls
