4 speed and transfer case
Las Vegas,Nevada
I have an extra 4speed and tcase ive acquired (H41) they are mounted together. Would it be possible to dismount the existing 4speed and tcase. and swap the
other one in without removing the bellhousing clutch fork,clutch, TO bearing and pressure plate? I plan on using a tranny jack or engine hoist. 1975 40 series.
Yes! I prefer to mount the trans / tcase after the engine (plus bell housing, flywheel/clutch/pressure plate/fork) vs all together.
I have never used a transmission jack. I remove the transmission tunnel cover and use an engine hoist through the drivers (or passenger's door.
Make you some guide bolts (cutting the heads off) for the 4 trans to bell housing attachment points helps to slide her in aligned.
You also need to be conscious of whether the input shaft nose on the H41 trans slides over the pilot bearing currently installed in your crank...tough to do in the crank tho. You could roll the dice and sand down the nose of the H41 with some emory cloth in hopes it's the right size...or just pull the flywheel/clutch/pressure plate/fork then replace the old pilot bearing with one you can confirm fits freely on the H41 nose. You definitely don't want to torque the nose into the pilot bearing and damage the bearing or something inside the trans.
