4" lift, steering mods?
USA
I am working on a roughly 4-5" SUA lift, and I'm wondering what steering linkage upgrades I should make. I'm going to replace the TRE's, but is there anything else I'm going to need. Should I go to a crossover setup, or use an extended drag link? Any good suggestions? Powersteering is from a Minitruck, and tires will likely be Q78 on 6" wide wheels.
Are you going to try to use your exsisting set up and just add the power mini steering box and pump?
When you install the lift all you have to do is use the correct front axle shims. Your steering will feel looser and the rig will tend to "wonder" while going down the road. Other than that you should have no problems.
I'm expecting some slack in the steering with the lift. I have a 2.5" right now, but I think I need the truck a little higher. I know I could run Q's on my current setup, but I think they will rub hard with a little compression.
Don't forget to factor in a new or extended rear driveshaft. I put in a 4 inch HFS with 3 in shackels and had the splines showing on the rear ds with only about 1/2 inch of contact, rig sat until I could get it done.
I am doing the same thing - I have a saginaw-ish PS setup. I will go to much beefier tie-rod & drag link than the wimpy stock stuff, and considering doing Chevy 1-ton TRE's just for kicks.
I will add back an Fj40 or Fj60 steering stabilizer to help control the 35x12.5's.
That's tight
