4 button Remote
Lafayette, LA (Tha Bayou)
Does anyone have this type of remote?
It is a 484T Coded 2/29 4 button remote
with FCC ID:EZSDEI484.
Here is a picture of the remote:
or a link to it here:
484T DEI Replacement Remote
I would imagine this is an after market alarm
and remote. I wish I could get another "style"
remote instead of the obnoxious 4 button style
I currently have. You really have to push the buttons hard to
get it to unlock and lock (arm and disarm). I ordered a new
remote and will need to program the new remote and I
have found the procedure using the search function.
My remote looks different from everyone else's though.
Any comments are welcome.
It's an aftermarket alarm so You could give it a try by getting a professional grade electronic contact cleaner spray with a fine needle hose and open the case, spray a bit in the center of the offending push button and push the button several times until you notice the led blink right away once you push it.
If this doesn't help, and you have a friend which is handy with electronic service (the service fee could cost more than the replacement remote) and has a soldering station with a vacuum solder removal tool and you can find new replacement push buttons in any electronic store you could replace them. Remember to clean the battery contacts with a pencil rubber eraser which is less likely to damage the contact metal plating which is the first one to corrode, something quite common if you keep the remote in your pant pocket. Remotes stored in the ladies purse last more !!!!!
Finding fashionable and compatible two button replacement remote is tricky if you don't work in this field because it requires some expensive testing equipment to find the radio frequency parameters of your remote unless the manufacturer recommends you one since they know this data.
Once you find the compatible remote you need to set your alarm module receiver in the "learning mode" and teach it the "electronic serial" of the new remote.
Some times, if the alarm is an older model and replacement remotes are expensive or harder to find, it make more sense to replace it at all with a latest generation alarm with the features you like and a nicer remote because the newer drains less power from the car battery in standby mode, the remote battery last more and it's harder to clone it.
