3spd t-case
Nashvegas
I have tried searching with little results. I have a 3sp case that I want to convert to a manual shift from vacuum. Can I use the front cone off of a 4spd case? Or do I need to find a set of controls for the vacuum case?
Yes, you can use the cone, or you can use the three speed cone. The difference is in the attached shifter rods. The length of the manual shifter rod differs between three and four speed but they're interchangeable and if you're going to construct your own shifter it shouldn't matter which you have - just affects the location of the hole in the floor.
I have a complete 3 spd transfer case shifting linkage and cone. If you need it let me know, pm me.
