Ok so I finally had some time this evening to pull the seat and see what the deal was. Here are some photos and conclusions I've come to.
First, the plastic half ring bushing seems to be both necessary and unnecessary at the same time. It isn't critical for the chair design to lock but because it is in the design the tolerances of the space make it absolutely necessary. Hope that is clearer than mud.
Here is a locked 3rd row chair with pencil pointing to the front bushing.
Without the bushing in place the chair will not clamp down.
I went to pull mine and at first thought I had three pieces missing a fourth but came to realize I had two halves of one and a slightly damaged other one.
Top (glues to chair bottom), note ridge on upper left piece.
Bottom rests/squeezes against chair rail on wheel well.
I must have split the one when wrestling with it a few days ago.
Below is the bottom of the chair and the two semi-circle slots (front and rear) the bushings glue into.
Closer look below, note the receiving grooves for the aforementioned ridges we noted in the bushing photo.
I'm not sure how much flex if any these plastic bushings are exposed to. I think/hope the loose adhesive caused them to shift and ended up causing the damage. I plan to superglue them back together and then back to the chair and see if that will rectify the issue for good or not. More when the glue dries.
Tub
