3M Rocker Panel Spray?
West of the Pecos
Anybody ever used this stuff? I'm planning to use it sort of the way some people use LineX or Rhino to cover the holes left where I removed the flares on my 80. I patched the holes with Devcon Plastic Steel putty, but I can't sand it down flush enough to not show under a coat of paint or there won't be enough of the epoxy left to stick in the holes... So I figured I'd spray some of this stuff over it to sort of hide the built up epoxy and then paint over the top of that.
Any suggestions?
I have used it. It's nice stuff, however i had issues with it not adhering to the surface. It would peel off pretty easy.
I wonder about backing the hole with a bit of fiberglass cloth, then filling and sanding down flush.
That would probably work if you sanded the inside around the holes and then applied the epoxy on the inside. I could have done that (thought about it), but decided I didn't want to pull apart everything that would need to come apart in order to access the backs of all the holes. I did put fiberglass wall repair "tape" on the back of all the holes I could get to. If I remember right, that was three holes per side on the front fenders and one on the left-rear.
The BEST way to deal with these holes is to have somebody weld them up, but I didn't want to go to the extra expense of having that done. I figure if the rocker panel spray works to sort of cover up the epoxy - GREAT. If not, I can always sand it down and do the "LineX Extra" color-matched stuff later.
Was this sprayed onto a sanded surface or smooth paint?
The instructions on the can say to sand it with 180 grit before application.
That's kind of what I meant by "backing" the holes . . . use fiberglass cloth on the back side of the panel and bondo on the front side, then finish and paint it. When I was a kid my neighbor used that method on an old Camaro and it came out pretty well.
At any rate it sounds like you've already tried it and it didn't quite do what you wanted, but I hope the tack you're trying now will get you what you want.
:cheers:
