3L cross post question
I knew of someone here in portland that had a 3L to put in a 2L hilux. He had the engine only and I think he had a lot of issues matching it up to a transmission.
Of course if you have an engine/trans together its not an issue.
The L series engines all share the same block I think so the engine mounts should be the same. I would be suprised if the transmission cross members would be different, but I say this with a Hilux in mind. The Prado could be different?? Do you have a wiring harness to go with the 3L - I think you would want one going from EFI to mechanical inj pump.
Is it really a good swap for the effort? How much power difference will you gain for the extra 400cc and no turbo? Or is this a "reliability" issue. Regardless make sure cooling system is 105% and go with a bigger exhaust with the 3L and you should be good.
:beer:
Keep us in the loop on progress!
I think there is a guy in Vancouver who has performed the swap and added his turbo from the 2lt to the engine and is very pleased.
Rob
:beer:
