3FE, won't start, codes 24 & 32
Northeast, PA
If you saw my other post (can I tow my new cruiser) you know I just bought a non-running 91.
:hhmm: I have a few questions.
I just checked for codes and it blinked out 24 32.
Do I have these right??
24-intake air temp sensor signal
32-air flow meter signal
Will these codes cause it not to start?
Are these 'fixable', or do I just need new?
Also, yesterday after pulling on various wires to look them over, now when the key is in the on position I can hear the fuel pump running. It was not doing this prior to inspecting wires.:o
Any ideas or suggestions on that??
Also, how much is a FSM and where can I get one??
I know I saw this answer some where but I've been searching so much the past few days everything is fuzzy. Way too much info here for my wee little brain to keep up. :whoops:
TIA for any help or info
I appreciate it.
-Aaron
It *might* be possible that all the above symptoms have one root cause; namely a problem with the AFM or its wiring. For example, I'm pretty sure the fuel pump isn't supposed to run unless the computer sees a signal from the AFM.
So what's it doing now? Crank but no start? Or...?
FSM here: Toyota Publications 1-800-622-2033
Curtis
Its cranking but not starting, and the CEL is on with the key 'on'.
From my prior searching I read that the fuel pump should not run unless the motor is cranking or running.
Taking a step back here:
A couple days ago I was searching and read where some suggested (to someone else with a no-start problem) unplugging the AFM and see if it would start. So I messed with it, I took the two philips head screws out and pulled the thing out a bit.
Now today (right after I posted my first post) I went out and took that apart again. Unplugged it and cranked it over.....nothing. Hooked it back up and tried again........nothing. BUT now the fuel pump isn't running anymore with the key on. :clap:
I checked the codes after all that and now I'm getting,
31-air flow meter signal
Does anyone know if a AFM from a 1st 4runner (22RE) will work on a cruiser??
They look the same except the 4runners bolts right to the air box. My buddy has a few extras laying around.
Oh Yeah, the metal clip that is on the AFM plug went MIA.
It flew somewhere on the other side of my garage.:doh:
Ok, that's bad.
That is NOT the way to disconnect the AFM. We've had several folks break wire connections in the housing that way. Some have had luck prying off the lid to the housing and re-soldering. Have you come across any of that in your searches yet?
Curtis
Yeah, I know thats not how it unplugs. but I took the screws out to take a peek in there. :o
No I didn't see anything about that while searching. I didn't know that was a no-no. :whoops:
That's just super! :rolleyes:
I guess I need to take it apart again and see if its messed up. :bang:
It was cranking but not starting before I did that though.
Here's what the AFM looks like under the plastic cover. Don't know if this pic helps you any, but what the hell. If you undid the screws that hold on the AFM side of the connector and pried on it, it's likely you've buggered the connections inside.
Thanks for the picture, that will help when I take the cover off.
Now....is there a trick to getting the cover off?
I can have a better look when I go home later tonight, but IIRC, you just slit the sealant with a thin sharp knife, then carefully pry it out. I think there is a lip around the bottom edge of the plastic panel which should limit the depth the knife will penetrate to. The pictured AFM is out of a 62, but I wouldn't think there was any change for the 80. Just in case it hasn't been mentioned, the air temp sensor is in the AFM, so its a common issue for both codes.
