3FE/Tire Size Question
Oregon
I am a newbie who recently bought a completely stock 1991 FJ80, after lurking here for a while and taking in as much information as I could. I apologize for yet another tire size/lift question, but I am wondering whether anyone has any thoughts regarding 33" tires with the 3FE motor. I will use the vehicle primarily as a cabin vehicle, driving mostly on Forest Service roads, some of which can be a bit hairy but none of which I would characterize as extreme - definitely no rock crawling for now. But it will also get a lot of highway use. I knew it was underpowered when I bought it, and I am generally fine with that, but I would like to have more ground clearance. What I would like to know is (i) whether I can run 33" tires without a lift and, if so, how much it would impact drivability on the freeway, and (ii) the same information with a 2 1/2" lift and 33" tires. Right now it cruises at 75 without much of a problem (although it takes a while to get up to that speed) except on steep grades, where I just get in the right lane with all the truckers and accept the fact that I'm slow. That is fine with me, but I wouldn't want it to get much worse.
If anyone has a similar setup, or thoughts in general, any information or advice you could give me would be much appreciated.
My thoughts.
I switch between stock 28s or 29s and 33s on my 62 (same basic drivetrain but part-time transfercase). When the 33s are on I spend a lot of time in 3rd and it is slow. You can get around, and it will do highway speed (struggling when the going gets a little steep), but it is nowhere near as nice to drive as with the stockers. I personally wouldn't run 33s without regearing, the overdrive in the A440F tranny is steep and doesn't work well with tall tires. Running in 3rd all the time will be hard on your tranny and fluid without a modified valve body to give you lockup (*edit* in third gear) at highway speed. Slap some 4.88s in you diffs and you'll be fine on 33s.
I have a 92 and am currently running 33x12.50's. It down shifts quit a bit when hitting a slight incline on the freeway but offroad in low gear it doesn't have a real big problem. Would be nice if it had more power but it's tolerable. I ran them with no lift for a good while on the stock rims and didn't have any rubbing issues when it was flexing. Heck I'm picking up 34x10.50's tomorrow since I just put the 2.5" OME on.
Go with 33x10.50s. They snug up nice with stock 91 rims and give decent clearance without a lift. They are considerably lighter than the 12.50s and still have no problem running in 4th at 76.
Keep your 3FE in tune and your brakes in good shape and you'll be just fine with 33s.
I'm going to play devil's advocate to RocKDoc and say I have no problems running 33's. I have had 33's for about 5 years now so it's hard to remember what the stock size drives like. Just this evening I drove about 25 miles on the hwy. and passed more people than passed me, I was not slowing anybody down. (Cruise control on 70 MPH, BTW)
Regearing would be nice but not necessary IMO.
Maintenance and proper tuning are important also.
(i) Yes you can run 33's without a lift. I installed the Slee factory replacement springs several years ago. No rubbing. Your gas mileage will suffer with the 33's. I get 11 mpg, mixed use.
(ii) I'll let someone with this set up chime in.
If your OK with the (lack of) performance from the 3FE, 33's 'should' not make you change your mind. If you live in a mountainous region that would change things. Going over mountains on the hwy. with a 3FE and 33's would get old quick.
EDIT: I am running 285/75/16's on factory FZJ wheels. So I would imagine they weigh more than a 33X12.5-15, I'm not sure though.
I would suggest getting the maintenance up to date so you are getting the most performance possible and then getting tires. Definitely do the maintenance before the lift, for various reasons.
I run 33X10.5's on my 92 with 1" spacers in the front and back. It does hurt highway performance (going up hills) a bit, but looks great and performs fine for me. Here's a pic last summer in the San Juans (Colorado).
33.12.5X15 Goodrich MT's KM2 on my 1992; no problem!!!:cheers:
I had 33X12.5 BFG K/O's. Now I have 33X9.5 Dean Mud Terrain X/T's. They are way smoother. I guess my A/T's were out of round. These are super smooth, with good acceleration and all that jazz. Twelve point five's are a bit wide and heavy for my taste. 33's work fine though.
Thanks for all the responses - very helpful. Any thoughts on whehter/how much a 2.5" lift would impact performance, combined with 33" tires? Also, I like Summit Cruisers' setup of just running 1" spacers; it seems like this may be a good solution to see how it feels before a lift. How do the spacers impact the suspension performance? Is there less articulation? Sorry if this is a dumb question.
I am running 305-55 x 20's on mine. (33.2-12-20) No issues other than one of my rubber splash guards rubs slightly at full lock. It fills up the wheelwell...but looks better than stock. I have no issues with power for these tires.
Put 20's on it! lol I may be the only one...but its not rock crawling anyway.
I could have put 1" spacers on it to eliminate the slight rub...but I wanted the tires under the fender flares, to minimalize damage from debris off the road.
pokey54,
The 33x10.5's I run with the 1" spacers make the truck look stock in respect to the tire to bottom of fender flair gap. I don't wheel too seriously just trail ride/explore in Colorado once/year. Suspension feels about the same. Maybe a little top heavy, but not really noticeable. Mine has 303K on it and honestly drives and feels just fine with the original springs and spacers. The picture I posted was loaded down with kids, gear, trailer and wife. Unloaded the vehicle looks level. I have looked into changing the springs to a 2.5" lift but I will only gain 1" on my hub to fender flair measurements so I have put that on hold. I think the 91 and 92's had stiffer springs than the later models. As far as performance, just keep it tuned up, make sure your throttle cable is adjusted tight and your transmission cable is adjusted tight to spec. and it will do just fine.
