I recently pulled my thermostat housing off and found what looks rust and holes behind in the head. Not sure what to do about it or is it trash? Need some input, thanks
Yikes!
Two options for you:
1. Engine rebuild, now
2. Drive it until it grenades. Get AAA if you don't have it for the interim, and diesel or V-8 swap it when she goes, which could be soon, or a little while still.
Casting flash. Totally normal.
Though it looks like there's a screw head and washer in the there too??
How about a pic from a little farther back so we can get a reference of what we're looking at?I recently pulled my thermostat housing off and found what looks rust and holes behind in the head. Not sure what to do about it or is it trash? Need some input, thanks
I would pull out the loose screw in there, put it back together and run it.
Thanks for the feedback, I was going throw it together and run it. It just looked weird to me. I'm a novice with these 3fe. it was running fine was tearing it apart to do a water pump.I would pull out the loose screw in there, put it back together and run it.
Cast iron doesn't rust like steel. That is casting flashing inside and is a non-issue.
It could do with a good wash, we dont alot of ponds to drive thru here in Arizona. But it is my hunting truck so doesn't help.Thanks for the feedback, I was going throw it together and run it. It just looked weird to me. I'm a novice with these 3fe. it was running fine was tearing it apart to do a water pump.
