3FE rear main seal
Provo, Utah
I have an oil leak coming from between my engine and transmission that has just recently started. I know the oil leaks in that area are usually associated with the oil pan seal, but I worry that my rear main is gone. I don't want to replace the oil pan seal and then have to drop it again to do the rear main so I am just going to bite the bullet and do everything. Anything else I should do while I am at it?
How many miles on your truck? Rear main seals tend to last a very long time.
You can differentially diagnose oil pan gasket versus rear main seal by removing the inspection plate and looking at the front of the flex plate where the torque converter bolts on to. If there's oil on the flex plate that's being flung off the plate radially, then it's the rear seal. If there's no oil on the flex plate then most likely it's the oil pan gasket. Another possible source of oil leaks on a 3FE is the side cover, but most leaks I've seen are at the rear arch of the pan gasket. (BTW, the oil pan can be stuck on surprisingly well and a real bear to remove. Be prepared to spend more time then you think needed getting it off.)
What is the trick to removing the oil pan? Any input would be greatly appreciated as I will be doing this same task!
You can differentially diagnose oil pan gasket versus rear main seal by removing the inspection plate and looking at the front of the flex plate where the torque converter bolts on to. If there's oil on the flex plate that's being flung off the plate radially, then it's the rear seal. If there's no oil on the flex plate then most likely it's the oil pan gasket. Another possible source of oil leaks on a 3FE is the side cover, but most leaks I've seen are at the rear arch of the pan gasket. (BTW, the oil pan can be stuck on surprisingly well and a rear bear to remove. Be prepared to spend more time then you think needed getting it off.)
Most folks have had good luck with the following technique: remove the front drive shaft and place a bottle jack between the frame and the side of the oil pan, using a block of wood on the pan side to distribute the pressure. Apply moderate pressure with the jack and then leave things sit for a while - even overnight if necessary. If you're lucky, you'll be rewarded at some point with the sound of the pan and jack crashing onto the floor.
But when I tried this on my 3FE the pan still didn't budge even with what I thought was a LOT of sideways pressure from the jack, to the point that I was afraid I'd permanently distort the pan. It took a lot of work with a 1" wide putty knife, working my way around both sides of the pan to eventually get it free. Either way you'll still be stuck with getting all of the old cork gasket off both the pan and block. But the reward is worth it. I went from always having windblown oil smeared around the underbelly of my truck and dripping on my garage floor to now having an oil-free undercarriage and spotless concrete.
EDIT: I strongly suggest using a Toyota OEM one-piece pan gasket. I looked at a few aftermarket gaskets, but none looked as well made as the Toyota. Also, as the FSM suggests, use a bit of gasket cement in the corners of the front and rear arches.
I'm not too concerned with getting the old gasket off. Is it really necessary to use a pre-formed gasket? I have always had excellent luck with The Right Stuff gasket maker.
It's up to you, of course. From the various Mud threads I've read, it seemed like no one has had problems when they used a Toyota gasket but this wasn't always the case with an aftermarket gasket. I don't recall reading anything about experiences with The Right Stuff. If you use, let us know how it works!
Lotsa XL Luck
excellent luck
You'll need that luck if you go with an aftermarket gasket.
The oil pan on the FJ62 we had for 18 years went through 2 aftermarket gaskets replaced by well-intentioned mechanics. The last said we'd need a new pan the next time around (sorry, it went to the next owner along w/OEM gasket).
The gasket on there now has welded to the block & pan, the sealant will resemble shellac IF/when you get it off. The jack advice would have helped the 1st mechanic (& the pan).
Both jobs lasted only a few years before the undercarriage resembled ducks after the Exxon Valdez. :grinpimp:
I don't know how the 1st mechanic got the OEM gasket off, but he probably earned the estimate in manhours.
Gladly swap driveways w/anyone not driving a 3FE for 18 years. :lol:
