3fe radiator replacement gone wild.
Mountainair, NM
I just finished doing some much needed work on our 1991 Bettsie.
I bought a CHEAP aluminum radiator last December and it was time to replace the CSF that had been seeping coolant for a while.
I drilled out the horizontal stud that secures the radiator to the body and replaced it with a bolt. The nut was temporary glued in place with RTV.
I replaced all the coolant/ heater hoses, straight pieces are 5/8" ID, 1/2" ID and 1/4" ID.
The worst looking hose was the straight piece right below the oil filter coming straight out of the oil cooler.
5 molded hoses toward the front of the motor I ordered from Toyota.
16261-61020 HOSE, WATER BY-PASS
x2 16264-61010 HOSE, WATER BY-PASS
87245-90K53 HOSE, WATER
87245-90K36 HOSE, WATER
I am also added a new w/4 gauge wire, parallel to the existing, from the alternator to the positive battery terminal. A new w/4 gauge wire, negative battery terminal to motor mount and to fender and alternator bracket to fender.
This upgrade was meant to prepare the system for a 12k winch but I also noticed that the voltmeter in the dash does not bounce any more when the turn signal is on like it used to. I want to report, No more voltage drop for the 3fe with this upgrade.
New battery tray 74403-60100.
New battery terminals.
New Jegs terminal block for fusible links and accessories.
I also removed the intake cooling fan and the very very noisy smog pump.
:cheers:
picture.php
picture.php
picture.php
picture.php
Did not want the positive terminal to be like this, what a mess.
picture.php
Ground terminal
picture.php
Jegs terminal block.
picture.php
My wife helped me with this one, a synthetic cork from a Cabernet.
picture.php
Ready for the winch...
picture.php
picture.php
With the aluminum rad. are you running green or Toyota red coolant? Just curious...
Right now I'm still flushing with distilled water.
I have been using green prestone and may just stay with that...
... you got me thinking now;
I could always go by the dealer, on my way to work, and pick up a gallon of full strength Toyota red. I think its $30 - $35 vs $10 for the green.
I'll make a choice by this weekend.
On the oil cooler hose that goes to the front.
Is that hose the same size on both ends?
Mine is leaking and a quick glance it looks to be different sized.
Nice work Frank. One tip if your radiator is the same as ours. On our 92 the aluminum radiator we got was spaced slightly closer to the engine. This resulted in the plastic fan blades interfering with the top hidden fan shroud bolt under full throttle. We ground down the bolt and ended up tapering the corner tips of the blades with a grinding wheel for added clearance. Cooling has been great and we did not seal the small gap that was created by the radiator being so slightly spaced back.
I've used Green Prestone for a while in both of my vehicles with absolutely no problems. I'm in South Texas and we've had 100+ deg for 25 straight days. ugggghhh.
Yes its 5/8" both ends. It looks bigger because it swells with oil. Access is from the bottom.
Thanks for the advice, we ran Bettsie pretty hard a couple of days ago. I'll check of any indication that this may be an issue. The gap I have is about 1/8" accross the front of the radiator.
Only 6 more weeks of this heat.
Green coolant in all our cars as well. It would just make it easy to stay that way. I just never had an aluminum radiator to play with.
Compared to the metal brass CSF, this radiator is 1/3 the wieght and cools very nicely, with ambiant temp around 100* and coolant temps staying below 190*
How did you wire the Jegs terminal block?
I'd like to do the same to clean up my wiring.
I am about half way thru this same project. I got everything unhooked on Saturday and realized that the aftermarket radiator that is in the truck had hard mounted trans cooler barbs and was in a panic trying to find the correct ones... didn't realize until tonight that the new flares were taped to the new radiator. I got the same radiator off ebay, glad to see it fit so well. Smog pump is on my list to loose sometime soon as well.
Go green. I would not waste any money on Toyota fluid at this point in the game.
This has been my game since day 1. It's nice to see a 'Yota 'guru' chime in w/the same thoughts. AFTER a good fluch, go w/the green & never look back!!:bounce2:
Punkrockpoppa and I put that same radiator in his 91. We ended up using Zerex G05 in it since I already had a couple gallons sitting around.
I have an oem radiator in my 92 (PO replaced 10 years ago, or about 45k miles) it has been removed and tested/flushed and deemed functional. If I swap it out with an aluminum radiator will it cool better? Tried everything to get the damn thing to idle in hot weather with A/C on without overheating, so frustrating.
Also, how much coolant should I expect to lose in about 6-8 months? The cooling system overhaul was done last summer (top-end overhaul, water pump, fan clutch, t-stat, temp sensor -all oem) and the first hot day drove the temps up, checked the water and it was down 1/2 gallon.
BTW the brand new green hub FC (stock fluid) is coming out this weekend to be warranteed for replacement.
Also considering electric fan... help!
Did you try modifying the fluid? I would try that right as you get your replacement.
Why is the fan clutch being warrantied?
It couldn't be the HEAD GASKET?
God Forbid........
It's not possible......
(that's all for @LS1FJ40 benefit)
You should not lose ANY coolant.
wow, I missed the part where it said it lost 1/2 a gallon! ya, that should not happen.. lol
Two thoughts:
1) you didn't "lose" coolant at all. There was air in the system when the coolant system was "overhauled". If they didn't properly burp the system you could easily be 1/2 low. Yours wouldn't be the first.
2) you had slow leak at one of the clamps that didn't show up 8 months ago when it was "overhauled" because the weather was warmish. It would've started weeping when it got colder out. Also very common.
I wouldn't hit the panic button. Swap out your stuff. When you add your coolant make sure the front end of your truck is elevated (park on a hill, ramps, or jack). Let your 80 warm up and listen for the thermostat to open. Watch for the bubbles. If you want to get fancy get one of the coolant fill things off Amazon. Or just use a funnel that fits snug.
