3fe motor mount
The Rockies or the Andes
Does the driver side front motor mount on a 3fe that has the setup to hold the alternator have the same bolt pattern as the corresponding 2f motor mount?
It occurs to me that it could be a good starting point for a bracket to hold the '60 PS pump.
Dunno. But I used the PS front motor mount and alternator bracket along with a 3-groove pulley from a 2F from a 60 to mount the ND A/C compressor that I use for OBA. :grinpimp:
I've probably got another smog pump bracket, if you need one.
