3FE Lifter Adjustment
Spokane, WA
Hey everyone! I’ve got pretty damn noisy cold lifters on my ‘92 3FE! They quiet down CONSIDERABLY after reaching operating temperature, to the point that I can barely even pick them out anymore during idle.
I read a write up from a Mud member regarding the adjustment procedure, and it sounds like a simple enough job. Between work I’m chipping away at my “baselining” items, and at least trying to prioritize them based on urgency.
How much urgency is there on adjusting the lifters on a 3FE?
I'd be careful trying to tighten up the valves to eliminate noise; set correctly they are actually supposed to be very loud and clangy. Definitely don't want to burn an exhaust valve.
Thank you! I’ve heard so much about 3FE lifter noise, and even had a guy tell me he adjusted his and the noise stayed the same!
As you said, the last thing I’d want to do is “fix something that isn’t broken” and adjust beyond proper tolerances.
I do believe there is such a thing as “over-maintaining” a vehicle, and I want to identify that line with my 80 and not cross it.
There is a good chance that precious owners have neglected valve adjustment. Many many people have never even heard of the concept. If you have not adjusted the valves since you got the rig, assume it needs to be done.
Adjusting them tight because of some perceived advantage of reduced noise is simply wrong. The valves would not be "overly adjusted". They would be out of adjustment. Do them. Do them to spec. Do them again when the time comes. Basic maintenance.
Mark...
Mark...
Thank you! So what is the level of urgency on this job? What would have happened if the previous owners kept the truck and never adjusted the valves?
Not the urgency of failing oil pressure. More urgent than a seeping oil leak. :)
As valves and seats wear, the valve can migrate upwards some in the head. This can result in too tight clearances. As the stem and rocker arm wear, too loose clearances can be the result. Too much clearance and the rocker arm will beat at the valve stem and the lifter will beat at the cam lobe. Too tight clearance and the valves may not be seated long enough to shed all the heat they need to or the valve may not even close long enough/completely.
The 3FE is fairly forgiving on this subject. Chances are no damage has occurred even if the adjustment has been ignored for eons. But setting the valves correctly maximizes engine performance. reduces excess noise and increases valvetrain longevity. It is a rock simple procedure, no reason to avoid it.
Mark...
Mark...
Awesome explanation!! Thank you so much!!
