3FE in Denver
Parker, CO
I have been lurking for some time now and may be ready to pull the trigger on a new (to me) LC. For some reason I am really partial to the 91-92s and may have found a 91 that fits the bill, but the question is how well the 3FE can handle the passes here in CO. I am not expecting a speed demon, but am hoping it can make it up at a reasonable speed 40-50mph. :doh:
I don't make it to the mountains all to often, with the exception of the Walden area which takes me over Cameron pass at 9000 feet. I a m looking to keep the LC fairly stock, only going with a 31" tire, sliders, etc.
Thanks for the great site and any info that can be provided . . . :cheers:
Welcome:flipoff2:. It should'nt be too bad..with that size tire. But dont expect to break 55. Especialy Floyd hill and the back side of Loveland pass.
Powderpig can lend a hand on 3FE issues in the Col. Mtn. But off the top of my head I would test the TPS for proper adjustment, do a valve job if the engine is sounding any bit like a diesel, make sure you're VSV is working for the EGR system and ensure the kickdown cable for the tranny is in proper alignment. Just some little things to turn your landsnoozer into a landcruiser.
I can't imagine having to deal with a 3FE in the Colorado High Country. The naturally aspirated 1ZFE sucks wind big time, the 3ForEver is going to be like driving an RV (and those of us behind you will thank you for that :flipoff2:)
Will it be fine? Sure. Would I change my partiality to a 93+? Absolutely.
I have to disagree you can do a lot with the 3FE :D
Yes, but can you do alot with a 3FE at 11,000 feet ? I've always heard that you lose about 3% of your power for every 1,000 feet of elevation. 3% X 11,000 ft = 33%, which means you are loosing 1/3 of your power when you are driving up to the tunnel. I know when I drive my truck at sea level it feels like I have much more power and pep in my truck. If you can deal with driving up some of these passes at 50-55 mph, then go for it. I went for a 1997 to get a little more power for driving up the passes.
FWIW:
We used to live in Edwards. (12 mi. W. of Vail) Our 1992 took us all over the high country in some pretty gruelling (some scary)conditions. I'd say that we averaged 48-55 mph when going over Vail Pass, Loveland Pass, or Floyd Hill. Yes, there were times we'd get stuck behind an RV or tractor trailer doing 35 mph unable to pass, but for the most part it became ritual to drive in the right lane. There's always the downhill to look forward to. If you only do an occasional trip up, I know that the 3FE will be fine... the biggest hurdle you'll have is getting used to merging onto the freeway in Denver. Best of luck in your decision!
So all I need to do at altitude is wind the boost up to compensate? :D
Sure, but the only reason to be partial to the 3FE in an 80 is to save money buying it - that's goes out the window with custom forced induction.
There is no question you will get from point A to point B. There is also no question you need a high tolerance for pain. If you need a good reference point, look at the number of 1ZFE owners with superchargers in the Rising Sun club. It's not because dropping $4K is fun.
I compensate with 5.29 gears and have kept additional weight as minimized as possible. If it was my only vehicle, I'd want a supercharger, but I have a minivan for trips that need speed.
X2 There are too many good things about the 95-97's or even the 93-94 to ever make me consider a 3FE especially since I live out west when I'm not stuck out here in corn fields.
Cost can be an issue, but think about the long run. If spending $1-4K extra to get into a 93-97 rig was going to break the bank, then I wouldn't have bought a cruiser. I have dumped at well over $2K into mine getting everything baselined and that doesn't include the fun things like S/C, lift, tires etc.
Regardless of you choice in the end, welcome to Mud.
Oh, God. Another 3FE Vs. 1Fz thread....:rolleyes:
And BTW it's 3FE > 1Fz just in case a few of you are wondering.
If POWA!!! was the only factor that distinguished the two, then yeah, :rolleyes: the 1Fz.
But like SOOOO much else you guys love to compare apple's and oranges together w/, these two can't be compared.
One actually HAS compression, the other, a mouse fart in a paper bag. So let's talk about that elevation again shall we? Only this time, to make it fair, we'll use a 9.1:1 HC piston set on the 3FE. And then compare it to the 9.3:1 c/r in the 1fz....
And the 3FE will still run circles around it in longevity.
Actually I have to be honest a stock 3FE in an 80 with Auto SUCKS for power but yes will out last a 1FZ and if you look closely the above pic is actually a 2FE-TI the best of all worlds.
Here in OZ we only go the 3FE in the 80 series with auto the manual was a carbi 3F 80 from 90-91. The 3F is far better due to no smog equipment to slow it down. The 3FE was a stop gap to import to the US meeting its emissions. That's why OZ never got a 62 series with the 3FE they were all carbi wether Auto or Manual. The 3FE here is like rocking horse s***.
91 fj80 in Boulder - I can go up Loveland at about 40-50mph with pedal on floor. I am looking to switch gears in rear diff and install Aussie lockers first available opportunity.
Note I hit a Big Horn Sheep on way hwy 6 outside Golden last weekend and truck almost fine minus front bumper and dent in hood from the horns. Glad I wasn't in a pissy little subaru.
That's good, because you're gonna have a lot of time on your hands puttering around at 40 mph :flipoff2:
:lol: shot who? stab what?
Cause when I get my stroked, 9.1:1 c/r, 2FE where we CAN compare the two, it's soooo on! :grinpimp:
Until then, it's like comparing a DC3 to a 727....
This is almost as bad as a Cruiser vs. Rover debate....
They are both EXCELLENT engines. However, the 3FE wasn't made for the 80. Rumor has it that the new drivetrain (1FZ/A442F/FF/etc) wasn't ready when the 80 was introduced. Again, just a rumor.
We're all Cruiser owners and clearly proud of it, so why can't we all just get along?
:confused:
The 3FE has lots of torque and is a good wheeling motor, but not a great mountain highway motor IMO. I have pulled a trailer with my '91 FJ80 crammed full of boy scouts more than once; it did so without complaint or missing a beat but not very fast. I recently gave it to one of my adult sons. It is still a daily driver for him at well over 200,000 miles. Believe it or not, the valve cover has never been off. Still has great compression; the only repairs in its life have been a new radiator, a new alternator, a new oil pan gasket, and a new cruise control speed sensor. And I soldered in a new wire on one fuel injector where the insulation had melted against the air injection rail. The culmination of the great "F" motors, but in the end did not have enough hp to push the great heavy beast the 80 series had turned in to down the highway at 80 mph.
And premium gas, while you're at it. Otherwise you'll have some serious pre-detonation.
That's what I can't figure out.
The 1FZ is 9.3:1 and the 22r is like 9:1. And those don't require hightest?
And, there's something funny I'm trying to figure out w/ the 3FE's timing.
You know the timing mod? I'm wondering how it would do with the higher compression? MAYBE, the pistons need the mod, maybe they don't. But I've never seen a 9:1 c/r that needed hightest.
:hhmm: I guess I'll find out when I get there. The 3FE is so un-popular, I think that's why nobody else has done it.
