Hope someone can point me in the right direction with the summary i am about to give.
Overheated my 3FE. Bought a used motor to swap in. Did the swap myself in my driveway. New to me motor fired right up. It seems to idle fine IMO. However it has a 51 error code and accelerates at about 1/2 to 1/3 the speed of my old 3FE. I pulled the throttle body and checked the TPS and it was within range. Just for giggles i took the TPS off of my old motor (which was working fine) and installed it and adjusted per FSM specs that i found here on Mud. Still same code and wont accelerate. Really feels like its running on 4 cylinders.
I wondered if it might be a wire problem so i checked connections at the ECU and then cracked open the harness at the firewall just inside the engine bay. Checked wires for continuity (spelling?
) from there to the connector at the TPS. No broken wires.
Where do i go from here? I feel lost.
Now the bad news.....its a 91'...STOP...put down the shovels and pitch forks...dont force me back into the 80 series section
I was told i would find more on 3FEs here than in the 80's section.
I have searched and read many threads but most seem to adjust or replace the TPS with luck. I am having no such luck. Thanks in advance for any help.
