3fe engine tune up suggestions
Park City,UT
Besides spark plugs and wires what are common 180k mi. engine tune up work that can improve the performance. The motor runs great with no oil leaks and starts every time. I have a K&n air filter but other than that every thing is stock equip.
Thanks
Valve clearance adjustment, ignition timing advancement, throttle body cleaning and Seafoam/Redline treatment, disable the EGR with the BBs method. That's pretty much my exact list and my 3FE runs like a champ.
I would search for it on here and in the 60 series forum. There is an immense amount of info on this board.
adjust the tranny kickdown cable so it shifts at 4000rpm with full throttle if it does not ,also tranny flush or change fluid and filter. only desmog if it does not have to pass smog, it should not have to,but laws are diff in some places.
