3FE Engine Replacement
Syracuse, Utah
Getting ready to drop in a replacement engine in my 91. Plan on replacing the rear main and was thinking about the transmission input seal. Was looking for the part number, but couldn't find it. Anyone have this part number handy? Anything else I should replace while I have the engine out? I have a new oil pan gasket as well...will go in after I get it bolted up.
Oh...also, the manual says to use "Three Bond 1324 or equivalent" on the flex plate to crank bolts. I have read differing opinions on what is "equivalent". Any help here?
I would go ahead and do that oil pan gasket before you put it in. I did mine with the oil pan on top on an engine stand it was easy. I've heard it's a pain in the truck.
I came across this post that talked about replacing the seal (P/N 90311-42010 -seal) and resealing the pan.
3FE Rear Main Seal
I called the dealership today to order the seal. They asked me if I wanted the oring as well. No clue where that goes. Any help would be appreciated.
Getting ready to install the flex plate bolts...any clue what is equivalent to "Three Bond 1324"? Have read loctite 242, 271, and 542. I am concerned with using high strength red (271). I think the 242 would be sufficient...any thoughts?
