3fe engine questions
Kalgoorlie
So just had the head gasket fail in my 3fe. There is a reconditioned 3f engine for sale. Is this suitable as a donor engine and do i just change over intake manifolds or is there more to it .
Otherwise i will have to strip it down and do an ovehaul
Thanks
How do you know your head gasket went, why dont you just tear off your 3fe head and rebuild it
it overheated. there is water in the oil and it runs like s***.
As to why not just replace it, the gasket kit is $150 of ebay and the local machinist wants about $400 to machine it up and test it all. it will probably take about a week by the time I start to strip it dow, then waiting for machinist and the reassembling.
There is a 3f engine reconditioned in perth for $600 and can probably do the swap in a few days.
I think it may be easier to change the engine rather than strip it all down as although I am mechanically minded, I am not a mechanic and not to keen on opening it up and finding more surprises.
Can you just use the long block on a 3F and still used all of the fuel injection pieces from a 3FE? If you do the swap and maintain your ecu you will probably end up with a CEL since not all of the same sensors are going to be getting power along the line but I think the engine will still run since its mechanical. Vacuum lines are probably a little different as well since you are adding a carb.
So I am assuming that the intake manifold and exhaust manifolds swap over but the main engine parts are interchangable ?
I am not sure we don't have the 3F here in the states but being toyota alot of times to reduce production costs two versions are usually compatible similar to to the 3FE in a FJ62 to the FJ80 similar but a little different you can put a 62 motor in an 80 but it requires just a little bit of mod at the bellhousing I think. I am not sure what all of the differences are 3F 19000-61390 has a different part number than 3FE 19000-61420
