3FE engine hesitate
Steve; we need more information about what your rig is doing and what you have done to try to fix it. Most common problems like hard starting, rough idling, and poor acceleration, are due to the simple things; dirty air filter, worn out mis-gapped spark plugs, high mileage on the distributor cap and rotor, dirty PCV system, loose or cracked air/vacuum hoses, dirty throttle body/butterfly valve and intake, dirty fuel injectors, plugged high mileage fuel filter, or old cracked ignition (spark plug) wires. Often it is a combination of all the above, unless it started suddenly. If you do not know when all these services have been done, or they have not been done for many miles/years, you could do what mudders refer to as "baselining" your rig. Meaning, do all the basic tune-up services and other maintenance items, then see what you got. IME (in my experience) with the 3FE engine, if you only have time to check one thing I would check/replace the air filter. If it has more than 8-10,000 miles on it, no matter how it looks, you should replace it.
