3FE Electrickery Questions
West of the Pecos
Couple of quick questions:
1) Any reason a 12v deep cycle marine battery would not work as an emergency jump or even replacement battery? I have one in the back of the truck I use to power surveying equipment, but didn't know if/how it would work in the 80 in an emergency.
2) What extra fuses etc should I keep on hand, "just in case"? Part numbers so I can order them from Dan would be GREAT.
Thanks!
I have a deep cycle marine as my 2nd battery. It powers everything from my winch to my subs. I also have it hooked up to a marine switch for a self jump.
It should work just fine as a jump battery. For long term use, I would not use a deep cycle since they like to be completely (or nearly)discharged. Regular batteries work well for intermitant loads such as starting.
For extra fuses, just carry the normally used ones. A couple 7.5, 10, 15, 20, 30 amp ones. You can buy them at any auto parts store, of for that matter, almost anywhere.
You should be able to jump your cruiser with the marine grade battery. And if I were you, I would just go out and buy an assortment of blade fuses at your local auto parts store. :beer:
