3FE distributor vent hoses
Manitoba
Just bought a 91 with a 3FE.
The vacuum lines were all switched around and it idled high. I think I've got that straightened out, but I want to confirm the two distributor cap vents are going the right places.
The big one goes to a filter under the air filter canister, and then there's a breather line into the cab through the firewall. I'm sure this part is right. The small one was connected to actual vacuum suction (circled in yellow). After reconnecting that hose to the VCV as shown in the diagram, I connected the small dist nipple to the 3rd connection at the air filter (3rd connection not shown in the diagram, which only shows 2, marked in red)
No more suction sound under the dash.
So: cab > dist filter can > dist cap > air filter.
Is this correct? I've searched and searched the forum with no luck, nor can I find a diagram or description of the dist breather lines in any manual.
Simple, but elusive.
Thank you.
If anyone else has this question in the future, here's my follow-up.
Seems like I have it correct. No more CELs. Engine runs better. High idle problem is gone. Ecu clearly is able to do its job of bringing idle to 600 rpm. Seems like success.
Yep - the canister. I think I've got it right now. Tank whoosh was one of the symptoms, but since I corrected things that has gone away. Thanks for your help!
