- Joined
- Apr 16, 2015
- Threads
- 7
- Messages
- 68
- Location
- Austin, TX
- Website
- www.patricklanephotography.com
Having a hell of a time getting FJ80 with 3fe to start. Rebuilt motor about 500 miles ago. Ran fine and then I upgraded old injectors with new four hole injectors about 50 miles ago. Was running well and then it stopped and will not start up again. Not getting CEL to come on while starting. Also not getting fuel pump to come on. Not getting spark at all. Checked relays, all good. I also replaced distributor, fuel pump, spark plugs, wires, coil and still nothing. Only missing to replace igniter. I can manually feed 12v to run fuel pump and hear it run though fuel lines to injectors but still no spark and this is only with manually feeding 12v to pull pump otherwise no fuel an no pump. No spark to distributor. Is there a fail safe that kills all spark in case of accident. Also tried a spare ECU and nothing. The last thing I did was upgrade the injectors to four hole injectors. Ran well for about 30 miles then died. Is it possible that the wires on the injector harness got to close to motor and melted causing a fail safe? Any ideas?
