3FE Block Flush
I inherited a 92 FJ80, and after experiencing some overheating problems over the past year have begun overhauling the cooling system. Disconnecting various hoses and shooting water in via a garden hose yielded HUGE amounts of rust and crud, particularly through the heater core. The little cooling hoses running through the throttle body were also totally blocked, and required some pressure to clear. Seeing the amount of crud built up just within the lines, I figured it would be best to just replace the radiator as there is probably an amazing amount of build up within it, which is why I must be overheating :)
The last thing I need to flush out before I slap my new CSF radiator in there, is the engine block. The block drain plug is VERY stuck and I am not sure that I'll be able to remove it. Is it possible to give the block a good flush shooting water through the top radiator hose and out the bottom while I have the radiator out? Or is there another route that would work better? I don't want a bunch of old stuff being dislodged into the new rad. once I have everything connected up and ready to go.
Thanks MUD
@jonheld
@LS1FJ40
These guys can assist in these questions. I tagged them, they should respond.
I just ran pure water for a couple weeks. I would dump and flush every few days, into a bucket. Once it looked clear with no crud, I drained and filled with Toyota Red. I was fortunate to have access to a lab with free Distilled water. I would suggest using distilled to keep mineral deposits out. Mine has been nice, clean, and red with my new CSF radiator for 2 years. We will state some obvious stuff here, 1) you can only do this in the summer or when temps will be above freezing, as there will be no anti-freeze properties in the water. 2) Leave your thermostat in, otherwise your fuel economy will tank and it does nothing to increase circulation when the engine is hot.
When refilling w/ Toyota red, get the non-premixed stuff. It is a better value, and there will be water trapped in your block which further dilutes the premixed. In this manner you can get the ideal mixture.
Also worth noting as these guys can attest, replacing the radiator is a pretty big PITA, at least much more so than the 12 minutes to took to do my XJ. I would also replace the upper and lower hose and there is a ~8-10" length of hose buried behind the water pump near the lower hose that you would not want to have to replace by later. One of the vendors on here very likely have an OEM hose kit available. If you want to dive a little a little deeper, this is a pretty ideal time to knock out installing new belts and the water pump. Use OEM belts, I did not use the OEM water pump but most guys on here will tell you that is a mistake. Regardless of the pump, I would use the OEM paper gasket, as the thin piece of rubber the aftermarket water pumps come with are certainly useless. You're on the right track, if you keep the engine with the right temps, everything plays very nicely.
Good luck, and enjoy your new rig. Don't let any of these FZJ80 guys tell you its slow, its the fastest tractor on the road.
I had the same problem on my 1991 with the drain plug on the engine block being seized, but there are two bolts there, one is a 14mm and the one behind that is 17mm I think, and if you put your wrench on the 17mm one and remove it you can then replace the whole drain cock assembly.
Try spraying the plug for a couple of days with PB Blaster (or other penetrating spray). If you can't get it off, just run your hose and flush the hell out of it from the top hose and let it run out the bottom hose. Remember to turn your heaters on to flush out the rear heater (ask me how I know...). I run it for about 10-15 minutes or so then catch some with a white pail to see what it looks like. If it's clear I shut off the garden hose and dump 8-10 gallons of distilled water through it to try to flush out the tap water. Then I close everything back up and add full strength coolant and distilled water. Toyota Red is the "preferred" coolant that people say is better. I don't know what the difference is. I do this every year which I'm told is overkill. But 23 years and I've never had a cooling issue. My original radiator and water pump lasted 17+ years.
Well, everything I know about the 3FE I've learned from @jonheld. And I only know about 3% of what he knows. I'd say that Jon has forgotten more about the 3FE than I will ever know but he hasn't forgotten anything about it. Hopefully he'll jump in with some insight.
FWIW, there are all kinds of "While I'm in there..." things you could address if you have the money. Water pump, thermostat, would be high on my priority list, especially since you are overhauling the whole coolant system. I suppose the water pump would be a "how old is it?" question but thermostats are cheap... Hopefully Jon has some better input on this. I went ahead and did both of mine when I did my radiator.
Good luck, let us know how it turns out!
I did try draining and refilling multiple times, but after dumping it this last time, the water came out very clean even after overheating. Pulling the heater hose from the firewall showed a huge buildup of crud that just wasn't being moved from the cooling system itself. Flushed her out real well though now :). I do know that it has a relatively new water pump (OEM) so I think I am good there. Thanks for the tips I'll probably do those hidden hoses as you recommend. Cant argue with an OG 80 owner:beer:. No complaints on speed from me. I love the way the old tractor motor rattles and growls.
I was wondering if I could remove that bigger one behind it! Thanks man, that's a huge help.
Thanks man I'll let you know. Yeah, I've been lurking on here and whenever a 3FE question comes up for me it seems like @jonheld comes up, so I'm kind of a secret admirer of his already:hillbilly:.
I've been letting that drain cock soak for a couple days with continuous squirts of liquid wrench, so we'll see what happens. Ill probably just flush it via hoses. I was debating whether to use Toyota coolant or some generic green, but I figure that now that I'm going to have new rad+thermostat+hoses and everything clean as a whistle, I might as well get some pretty red punch in there.
Thanks for the help guys. CSF rad came in via Amazon today, so time to continue with this mess. I'll post up some shots of what I found in the hoses when I get the chance. You guys will die.
Remember with the heater core, the hot water is only flowing through it when the valve is opened by cranking the heater dial to red/hot. Possible now that its warm, the arm is not set there.
Replacing the heater core is a massive pain usually. If just crud is coming out, it likely means its in rough shape on the inside, but not clogged yet which is good.
There are plenty of threads on there about flushing that. Guys have used CLR, I had excellent results with Oxalic Acid (wood bleach). If you do anything like this, keep it contained to the heater core, you dont want chemicals flowing around the system. Also, this is a bandaid, it will remove a bunch of rust and debris, but unfortunately over time the internal corrosion cycle continues.
Great news on the newer water pump. Did you say the truck is actually overheating? Like the temps are above half way? If so, check the condition of your fan clutch and shroud. There is a plethora of information on there regarding those.
Jonheld is definitely the oracle of 3FE, he has steered me correctly a few times when I was just stumped.
Good luck man, and welcome!
FWIW I once bought a used car where the PO had mixed GM orange with green and the result was brown @#$!. I ran garden hose water and Cascade for a few days and then rinsed once more with garden hose water. Before filling with distilled/coolant mix I used my shop vac on blow to push out as much of the tap water as possible with t-stat out I disco'd the upper and lower hoses from the rad and blew into the upper hose and upper port on the rad.
YMMV contents may settle in shipping...
My LC the PO had the HG changed at TOYOTA dealership and they did not properly flush out all the red before refilling with green. The result was brown sludge that dried on my radiator cap, causing it to NOT open in an urgent condition, then exploded my radiator. No, it did NOT result in a blown HG after the fact. (had it confirmed by no loss of coolant and a Blackstone analysis.)
I flushed with a garden hose for 30 minutes, then (6) full rounds of distilled water and driving to work and back, then finally draining and filling with Red. Looks like Fruit Punch Gatorade now.
You were lucky!
You were lucky!
Yes, I was. I was seriously debating on just yanking the head and changing the gasket due to the severe over-pressure condition, because I was SURE I was going to put it all back together, just to find it had a HG leak. I'm glad I hedged my bet on that one and didn't pull it. None of the signs were there before hand.
I did a Blackstone at 4800 miles on the oil, and they said that I should consider running the next oil change to 7000 miles because there was so little wear and issues in the sample. That made me feel really good about the health of my engine, in spite of the horrible neglect the PO did. I truly feel I brought this thing back from the dead. They were going to donate it, and with as much work as it needed, it would have gone to auction and sold as a vehicle to be parted out.
The guy's wife asked me a couple months ago if I was tired of working on that old truck yet. I said: "No, that's my therapy and I enjoy doing that sort of thing!" I admitted to them that if someone else got the truck, it would have cost a fortune to rebuild it from the dealership or other shop. Well over what it would have been worth when done.
I want to do mine is there any special way of doing this like which hoses do I disconnect and which do I flush through.
Consider that with the thermostat and the heater control valve removed you have a pretty clear run though everything. So one of the zillion ways would be to pull the t-stat and replace the heater control valve with one of those prestone flush adapters. Petcock will drain it out but disconnecting the lower rad hose at the rad will drain faster.
Okay, so I had to put my project on hold for a bit but a couple days ago I finished! Toyota radiator cap, CSF radiator, Toyota thermostat and gaskets. It seems to run a little smoother, particularly at startup. Maybe because the temperature sensors are now working as they should? Here's some gore:
[/IMG]
[/IMG]
Yeah thermostat out makes it a lot easier. I tried to always have one long hose to stick my garden nozzle into, and another long exit hose so that I didn't get the ejaculate all over the engine bay. There's also the little hard lines that cool the throttle body too, mine were clogged.
Also try to flush in both directions for each section you're flushing. I found that I got a lot more out that way.
