3b struggling to start
I Have a bj73 1985 with the 3b, the battery is a few months old but the engine struggles to turn over even when i charge the battery. it sounds like the battery is flat when it is cranking over, is this a problem with the starter motor?
Also when on rough tracks the battery light on the dash will flicker, are these 2 issues related?
check connection; bttery-startermotor-alternater-ground.(with good flashlight)
retighten the connections and use some electric cleaner.
try again with a charched battery.
if that dont work open the startermotor and check brusches.
check fuel suply line.
but i think it works becous what you said what happen on rough tracks
I would assume you have a bad connection somewhere.
Remove the terminals and clean them up, and clean up your ground as well. Clean the starter post also.
What voltage is your battery reading (with a multimeter) ?
Thanks for the replies,
I will check and clean the connections on the weekend and let you know how I go
