3B - poor idle, smoke when starting
G'day All,
I've got a 3B in a 1985 BJ73 and when starting absolutely cold in ~14°C (57F) temps it will run very, very rough at idle (fine at higher speeds) and produce loads of white smoke on startup and soot for the first 30 seconds after starting. It is noticeably smoother and less smoky on starting with just a 5°C ambient temperature increase.
However, after a 1 min run at ~900rpm in any of the aforementioned starting conditions and turning the hand throttle off there is no smoke of any description or soot and a perfectly smooth idle. It runs like a dream after the dodgy starting.
It cranks fine with no smoke/soot etc later on during the day while there is still some temperature in it.
I'm tentatively hoping glow plugs?
My vote goes on the glow plug. I'll bet one (or more) are shot ! In all cases, it is the first test that you should do when there are symptoms such as those described.
You have to remove the glow plug connector before performing the test.
Just checked continuity on the plugs - 1, 3 & 4 have continuity but nothing on #2. I'll get a new set of glow plugs and fit them this weekend. Here's hoping that will fix the problem.
