3B Oil Lerak -help
Bradenton Fl
I have an annoying ,small leakat the front of my 3B.I thought it was the side plate ,but after a good re tightening and wash down I believe it is possibly water pump or head gasket leak-I dunno. Has any one had similar leak??
Most likely the head gasket, wash it down and take it for a good run (nice and hot ) then have a close look. Mine leaked coolant from that area and oil from the side of the head??
Good luck
oil leak
It is not coolant and it is not from the valve [Rocker] cover.SO, My best guess with your input is head gasket.Could it be as simple as re torqueing [sp] the head bolts??
Hey Joe,
Oil can creep along a joint like the ledge between the head and block for quite a ways. If you have cleaned the engine carefully, you can inspect the areas all around the head to see if there's a leak from above leaking down onto the joining area and spreading out around to behind the water pump.
I have never had luck with torquing head bolts to eliminate a leak. Head gaskets once breeched are due for replacement. My guess the reason why is that the thin film of oil under the gasket dosen't allow complete clamping and thus leaves a seeping passage.
Wait, one exception: The 22R gasser has a timing chain cavity at the front of the head with a small internal bolt that could be loosened, cleaned, silaconed from the inside and torqued down for good results. But that wasn't a head bolt.
Hope yours can be repaired without extraordinary measures,
Rick
oil leak creeping
Yes I know oil can creep a long way.Just finished cleaning and tightening obvious bolts [wishfull thinking] and will take a rid and warm her up well and take a look see?Engine runs fine ,leak is not bad enough to replace head gasket at this time IMOP.
I think you're on the right track with the creeping oil. I've done the clean-and-drive about 6 times now tracking leaks down.
That said, there isn't much around there that it could creep from; the only thing higher is the head gasket or valve cover.
Don't do what I did, however, and rush to replace the head gasket. If you *really* end up having to, don't worry, as its not hard: https://forum.ih8mud.com/diesel-tec...at-hell-wrong-now-head-gasket-head-crack.html (also some pics of the gasket in that thread; theres virtually nothing in that area apart for the head bolt... no passages, etc)
My Leak
So I took a drive to the hardware store and back , leaks started again and I think it still is the rocker adjustment cover that is leaking.I think I will wash it all down again when Hot or at least warm and then start her up and watch for the oil / leak as it idles a/o my friend runs it up??
Glad I might be right. While you are at it you can adjust the valves (done while the engine is hot) Pick up a new seal and torque the valve cover down according to FSM. I say this because I once buggered it on a car reading foot pounds for inch pounds. :whoops: Recheck the torque after a few long runs.
I bought a new gasket from Toyota just days ago; I couldn't believe that it was supposed to like like a rubber oring, considering the crushed crumbly POS that was currently in there.
Torquing the cover with a new gasket isn't straight forward because its so thick and soft. I tighened each fastener repeatedly until they all read 8 (or was it 9?) ft lbs. If you do them one in one pass the ones you started with will be less than finger tight by the time you reach the last one.
Oil Leak
I believe it is the tappet / side cover thay is leaking . I cannot find any oil at rocker cover seams or drip down.I replaced the side cover gasket [cork],Thought I did a great job too, BUT ,it is still leaking i believe ,even after re tightening.Might go neoprene or just a large tube ofblack rtv or whatever it is.
Well in that case I have more advice still! I've had my side cover off 3 times, all three times I skipped the gasket and just used Ultra Black RTV... 2 of those times it worked perfectly, 1 time it leaked through the RTV.
My lesson learned is that you've gotta make damn sure the sealing surface is clean and *free from oil* before fitting the RTV'd cover. I wipe with towels, degreaser, water, and more towels.
[All that said, thats a long way to crawl from the side cover... the area you show is at the top of the cover; upward leaks are less likely, though not impossible...]
Still good news that it isn't coming from the head gasket. Just don't tell my wife I was wrong.:grinpimp:
I have never had Ultra Black leak on me yet. But I always dampen a shop rag with brake cleaner and clean the mating surfaces well.
