hi all
I have had a bit of a hunt around looking at EDIC stuff but my problem seems a bit more unique then the common problems with the EDIC unit.
1895 BJ73 with a 3B was running fine until i messed with the following.
New 55W ebay headlights
Removed crappy old spotlight wiring and did all new wiring with a relay running off the high beam wire behind the headlight, power for relay comes straight from the battery. 4x100w spotlights on the roof with all 6mm diameter wiring.
Now when i turn on the parkers - all good
when i turn on the headlights the EDIC motor continuously cycles
when i turn on high beam the EDIC motor continues to cycle
when i turn on the spotlights (via switch in relay circuit) the EDIC motor cycles a little faster.
got me stumped?? is there a link between headlights and EDIC?
Thanks
Thanks
