38mm Weber help needed
the throttle plates pass through the adapter under full throttle. Take the carb off and see if it works fine off the truck.
You might be able to look down the carb (engine off) and see it the plates are hitting anything.
I know that if I take the idle adjustment screw too far in on my stock carb, it will actually bind the linkage to a point where it will stick open. I cannot envision a Weber at the moment but that might help.
