37's
I ran 35" trxus at high elevation for a year and a half before regearing. It was no different than running 33's (they both sucked).
It was really crawling at high elevation that pushed me over the edge to regearing. No question it is better with 5.29's, but at my elevation it's still a dog up the big hills, and I had the 5.29's with 35's for a long time before moving to 37's.
Of course I don't have a 3FE, but then I also live at 7,400 ft elevation, which is also about as low elevation as I ever wheel.
You will regear at some point, there is nothing wrong with doing the tires first unless you just have to have speed on the highway.
37's are last decade for sure, but if you aren't changing the trails you run I don't think they are a material risk for breaking anything over 35's, and to a degree I think it is safer because an 80 on 37's handles the rocks so much better than an 80 on 35's in terms of being able to crawl.
No doubt 39's would be the ticket, but I'd be doing some high clearance custom 60's and redesigning the suspension from the ground up before I chased that dream, and that's a good $10K-$12K project just to go up a tire size in a rig that's too big anyway.
:steer:
thanks for the input nay. yeah, kinda sucks that there arent true 35" tires available from the likes of GY or BFG...just 315s which i dont consider a 35. thats why im looking at the intercos. just a bit concerned at running the softer trxus (or even the SSR's) on a 5000+lbs awd wagon. i live at sea level, so altitude isnt a problem, but there are some mountain passes here i frequent at times with the trailer.
Interesting.
It doesn't look like such a drama to go 35's or 37's.
Now you guys are tempting me!!. I don't consider 37" yet, but may give a try with 35".
Tell me one thing: regarding fuel consumption, how much would it increase if we compared 285/75/16 with stock gearing vs 315/75/16 with 5.29?
315s with stock gears wont be much worse than the 285s with stock gears. fuel consumption might increase slightly in city driving but you could make it back on hwy cruising. i would think 529s would be a bit low for 315s though... unless you dont cruise @ 75mph on the hwy very often.
I think you might have meant to say decrease, because that has been my experience with stock gears. In stop and go city driving my mileage is terrible with 315 coopers (~34.47"). I'm usually right around 9-11MPG city if I'm lucky, less if it is a short trip and the engine is cold.
However, on the highway I have the same if not better MPG with the 315's vs. 285's in the same tire- usually around 14-15 MPG, sometimes as much as 16-17 if it's flat and I keep the RPM's around 2k. That is with a S/C, and a roof rack FWIW.
It will be very tempting to go up to a 37 when these wear out. However, I think gears would be in order at that point. I'd also have to switch to a different tire since I'd like to stick with the OEM wheels and Cooper only makes a 37 in 17" wheel. IMHO, 34.47" is the max size I'd be comfortable using with stock gears. Anything more would seem too sluggish, but I can't say for sure because I've never driven with 37's and stock gears.
isnt that what exactly what i said? :p i think a true 35 like an interco which almost measures slightly bigger than 35 would be the most id go with stock gears...as the intercos are heavy sob's. 36+, id definitely not ride on stock gears...for too long anyway. i dont want to change rims either.
nay, could you post up some pics of your 35s vs 37s?
I had ZERO mpg increase going from 4.10's to 5.29's with 315's. And FWIW my truck is a dog at elevation... I am about to go to 37's so we will see...
Not a perfect comparison, but should give you an idea. The first pic on 37" Trxus is before the 1" wheel spacers, the second pic is 315 Toyos.
A couple more, first on 37's, second on 35's, both Trxus.
And one more set, again first is 37" trxus, second 315 Toyos.
Nay's a poser. :flipoff2:
I'd say the 315's are 35's according to how the industry measures tires, 'cause most so-called 35's aren't 35". It's rare to find any tire that measures up to what it says on the sidewall. It's all relative until you get to where you're looking for that last 1/4" of clearance at the front of the rear wheel well, where you just can't cut anymore. :hillbilly:
yep its true for sure go for the 37" even after you get the 37" youll catch yourself saying " those dont seem like 37" at all, i could probably go bigger on the next set" youll see youll be suprised how these big ol' pigs even make 37" tires look/feel small
Sad but true :hillbilly:
You can get a smallish 315, but for all intents and purposes a 35" trxus and 315 Toyo, for example, are essentially the same size.
To the previous post, 37's are the first size that start to feel "big enough", kind of a like how 33's are the first tire that feels that way on much smaller rigs. Meaning, scary as it seems, 37's are still pretty "in the box" for an 80.
You gotta go really big to start getting into more serious trails, 37's make the good trails where 33's probably mean taking some bypasses a lot more fun, but they don't get you anywhere near the really hardcore stuff.
ive found the intercos to measure larger than stated. i had a 35X12.5X16 trxus as a spare on my 4runner which was running MT/Rs in 315s. it towered the goodyear. my buddy was running 33X12.5X15 trxus on his runner and it was slightly taller than my MT/Rs as well. perhaps iroks and tsl's are a different story. im strictly speaking trxuses (truxii?) here.
true that. the toyo does look pretty big. perhaps tread design plays a part in how big a tire 'looks'. but the toyos also a heavy ass tire. howd you like the toyos on your 80 btw?
the only really hardcore stuff around here requires an exo or lack of concern for a straight body. i think 35s would be perfect compromise of DD'ing and WW'ing. run it on stock gears till i can regear. just worried about wear on the intercos... want them to last at least 3-4 years.
you ran the 315 toyos on stock gears before running the 35" trxus right? was there any significant difference between the two?
