37''s or not 37''s
you can run 40's with just a springover and no lift springs...
You can....but teh sawzall is your friend...:D
I'm running 37s with a so and leaves removed from a 2.5 lift.
Sure you can, I have a 4 in. lift from skyjacker, 2.5 in shackle reversal from man a fre. I fliped the rear spring for more wheel base & have 2.5shackles from cool cruiser in the back.
look for Treeroot's truck so you'll get an idea.
I wouldn't recomend a 4" lift and soa. You could probably run 53's with that much lift. I'm on OME 2.5" springs and I could probably clear 40's at full stuff with no bump stops in uncut front fenders. I run 38.5 x 16x 15 tsl's and it's really too tall for them. I have thought about lowering it a little, but I do a lot of snow wheeling and my plan at some point is to find some 44" sand tires for more floatation in the snow. I'm sure they would clear for normal driving and may rub a little at full stuff. Here's a pic of the height soa on 2.5" leaves.
