37s let you do WHAT???
Logan, UT
vs. (true) 35s
Living in Utah, and wondering about what those of you who moved up to 37s gained on the trail. I can mount a set of new Trxus for $700 in 35", and just need a good explanation of what level of trails you have to encounter to avoid bypasses.
Rubicon on 35s"?
Pritchart (sp) on 35"s?
In other words, another $600-700 gets me what? I am convinced 37s look "right" on the 6" lift, but wheeling gains are unclear for that 1".
s :cheers:
It gets your rockstar parking at just about every club you go to.
:flipoff2:
As for your question, I don't know. I've had 37's on here since I bought the truck. Nay would be a good one to ask about that though.
I did 4.0 rated trails on 35's. I do 4.0 rated trails on 37's, just a little easier. It's not night and day. They give you a slight advantage, but not enough to follow buggies. IMO once you're lifted and on 35's, you're close to maxing out the truck, any further mods are just going to make the trails you already run a little easier. It's still a 3 ton station wagon.
Ditto Spike's words.
37s will indeed make trails easier, less dragging and banging. 35s crawl better, being a bit smaller. I did Rubicon three times on 35s and once on 37s and it was easier on 37's. Fun factor was the same. Suggest 5.29s and for sure a set of Longfield axles and birfields.
Most of us don't "need" 37's, me included. I will be honest and say that I cannot stand it when my rig doesn't look right. 35's were too small on a 3.5" lift, 37's are perfect. When I am sitting at Starbuck's and look out the window at my rig, I get a "damn that's sweet" feeling. Not the case on 35's.
Now to the real question: 37's I think are the tire size where you finally feel like you have enough rubber under an 80 if you have wheeled a smaller rig in the past. I've stopped candy caning my driveshaft, my diffs are happier, and the rocks on the trails I was running on 35's and still run on 37's are smaller :D
37's are not class changing, but from a trail perspective I did not want to go up a class because the next level up is damage mandatory for a rig this size. That is why I'm not terribly concerned about 37's suddenly becoming a birf buster - it is easier to run the same trails than it was on 35's in needing less throttle and dealing with fewer hangups, so I could argue that the 37's are less stress on my components than 35's were.
In your case, if you do a lot of Moab wheeling, or Moab type wheeling, your extra lift is a lot more important than 35's vs 37's because Moab tends to test breakover and departure angle as much as anything else.
For big rock gardens I'd want the lift and the rubber.
So I guess it comes down to this: you have enough lift to really push it (running Pritchett vs. say Golden Spike), and if you are going to push it you are going to wish you had 37's if not 39's.
I would never go back and I have no desire at all to go bigger. And that's the best place to be in a 4x4 project: satisfied.
Wheeled with 35's and 37's on the Rubicon several times. 37's definitely made a difference for me, I will never go back.
Nay is right 37's just look right for the 80 as well.
eat more gas...
My fuel economy is unchanged over 35's. I still get 13-14 mpg in normal highway cruising if I keep top speed between 65-70 mph, never worse than 12 mpg in mixed use.
This is better than when I had 33's on stock gears.
Our inefficient engine is affected more by drag (lift) and under gearing than by properly geared large tires.
I'm finding out 37's aren't big enough. I need 42's. I want to wheel with the big dogs.
Question...
Those that are rolling on 37s is it fair to assume that you stepped up from 35s? The reason I ask is, is it the tires that are making the difference or is it the seat time on the trail? i.e. if you went through 50% of the tread or three seasons on 315s and then stepped up to 37s one could assume you've developed your driving skills which plays more of a role than the .75"-1" of rubber diameter.
I don't disagree that tire size can and does make a difference but it is not the end all be all because it won't compensate for driver skill or the lack of. I feel confident in saying that nearly everyone here who has been wheeling for some time and developed their driving skills can say they have out wheeled more capable rigs. On more than a few occasions I have out wheeled guys rolling on 38"+ tires and I bet many other 80 owners on MUD can say the same. Would I trade my 315s or 36s for a 37 or 38, probably not. If there comes a time when I feel I need that large of a tire it'll be time to build a different truck (40, Mini or runner).
Question...
There is no question your driving skill is more important than one size tire up.
Having said that, going up that size makes a big difference for the same driver in the same rig on the same trail.
That's why guys with a lot of seat time are really considering 40"+ tires and the more significant mods. If you get it right, it will change your game.
I am personally not willing to give up the fact that my ride home is nicer than in the average tow rig, so I stop at 37's.
But the big thing in many ways is just being satisfied. I got there with 37's when I thought it would happen with 35's. Many get there on 33's, some even stock.
But you have to hate getting the tires a size down than would easily fit when you plan to wheel hard, especially when punks are posting up their pics on your favorite forum :hillbilly:
