350 w/hei vacuum question
nat
Los Gatos, California
I have a question about what port the vacuum advance needs to be hooked up to. I have a chevy 350 with a 600 cfm carb in my FJ55. I thought I had read somewhere that the HEI distributor needs to be connected to a ported vacuum source (one with no vacuum at idle) Do I have this all mixed up? I can not seem to find any of my info about it. I bought the motor as a new crate motor, currently it is hooked up to a regular vacuum source and my throttle response is not what I think it should be. It is timed perfectly at 10 degrees BTDC. I have had a couple issues with the motor so I would not be surprised if someone hooked the line to the wrong vacuum port on the carb. Thanks for any help :cheers:
It is a Holley 600 cfm, electric choke, vacuum secondary, nice and shiney looking. :grinpimp:
those appear to be the best pics I have of it right now.
No need for manifold vacuum at idle. What carb? Off idle circuit has some debris in the ports? Primary jet change needed? etc.
The hotrodders are a wealth of info, for example:
http://www.hotrodders.com/forum/where-manifold-vacuum-port-quadrajet-4mv-31584.html
sorry, didn't wait for the pics to show up. I know zero about Holleys. Still, in general you should not need vacuum at idle and throttle response relies in part on the stuff I mentioned. You just have sluggish response and not stumble? Stumble can be float level, power valve, accelerator pump, etc. Bound to be a few Holley guys on hotrodder.com!
The vac advance distributor needs to be connected to a ported vac fitting on the carb. Use a vac guage to find a ported vac fitting. With the engine idling, the ported vac fitting will have low to zero vacuum, but as soon as the throttle is cracked above idle it should show plenty of vacuum.
Set the base timing with the engine idling and vac hose disconnected and plugged, just to be safe. If it is currently set to 10deg w/ manifold vac hooked to dissy, then when the throttle is mashed vacuum and ignition timing will go away, killing response.
I second jim, you must have the ports already plugged if the engine is running right at idle as is. If i remember right, and will try to confirm, but one port is right above the idle screw on the passenger side, near the front. It is a smaller port, not the big one for the PCV.
Just threw my vacuum gauge on it this evening, the distributor was hooked to the non-ported source. I have it changed now, we will see if it makes a difference.
My next problem is my brand new Holley carb with only 4k miles on it has isues and needs to be rebuilt. Had a crappy call with Holley today, not happy with their customer service :censor:
My latest holley horror story:
We put a brand new Goodwrench Performance crate engine in a truck. It was complete w/ intake manifold, HEI dissy and new Holley vac secondary 4bbl. Well, it ran like crap and was hard to tune and set float levels. I finally removed the carb and tore it down. The d%&m thing was full of metal filings from manufacturing. :eek: Seriously, there was a teaspoon of aluminum powder in the primary bowl. So, after rebuilding and rejetting the "Brand new, ready to run carb" it ran OK.
Thanks Holley!:flipoff2:
Shoot, I wonder if that is what the problem with my carb is. I ordered a rebuild kit from the parts store, the carb will not idle or consistently keep the air fuel mixture right. I got the deluxe 330 HP 350 GM crate motor.........sounds like what you got.
I already had to replace a float bowl gasket, they had put it in wrong so it leaked gas like a sieve. Saturday the carb gets torn down.
