350 question
Orem, UT
Website
www.fjwear.com
this hole (look at attach image) is on the driver side of a 1990 chevy 350. I am looking for a place to install a oil pressure gauge. I was wondering if anyone knew if this is coolant runs through there or is it oil. The passenger side has one about the same place where the knock sensor was so It might be the same but I don't know.
Thanks.
- Rico.
My WAG is that one is in the water jacket, but you could unplug it and see what flows out?
I am plumbed into the top of the block at the back on the driverside, you may need an adapter to clear the intake if using the stock toyota sender.
Note: the blue hose goes from the block to a mechanical oil pressure guage in cab. I also do not know if my earlier (80's) era block is identical to your 90's block...
Yep, that be coolant on the other side of that hole. Rear top of the block is best place to read oil pressure (Planet_X photos).
that is where the current oil pressure sender is and I believe the ECM uses it. I was just looking for an easier way to install the gauge w/o having to tap into the current piping.
Thanks.
- Rico.
Thanks.
- Rico.
I just posted up a pic in the " 350 swap, clutch issues' thread, you can see a pipe plug right above the oil filter pad of the block- this would be my alternate choice, pretty sure oil is going to come leaking out've this one, but verify as I have misplaced my Chevy tech manual showing the galleys in the block.
yep. I had the same post on Pirate and someone said to do this.
Thanks for the info guys. I think this is going to be the best alternative.
- Rico.
Yep, that plug over and to the right of the oil filter is an oil line. On my 350 I plug my oil pressure gage there.
