33X12.5 questions
I have spent several hours looking for the following information and I can't seem to find it. so I hate to ask this but here it goes:
I would like to do a suspension lift to fit the 33X12.5 tires I just bought, I would like to do the OME but I can't figure out if this one will work:
http://www.man-a-fre.com/parts_accessories/omesuspensions.htm
and should i buy the basic kit or the deluxe and do you need the Shackle Reversal kit or do I get the:
http://www.man-a-fre.com/parts_accessories/safari.htm
This is going to be a daily driver.
last question what is the backspace i need so I don't get any rubbing on the tire. I have read 2" to 3.5" so I am a little confused.
Thank you
Never go more than 3.5" BS. Go less if you must but not more. I wouldn't mind upgrading to 2" BS. This widens your stance a little and gives extra clearance to the steering components.
A 4" lift kit seems to be a good amount of room for 33's although at full flex mine still stuffed into the fenders pretty hard.
SR FAQs
3rd 'section' down on the left
Some like it, some love it, some hate it...Opinions are like, well never mind on that :D
As for lift...Here might be some semi-useful info RMC - toward the bottom. Personally I'd probably go for the deluxe kit assuming you are going all new anyway.
GL
Hi All:
I have been using the 2 inch OME suspension on my FJ40 since 1998, with 33X12.5R15 tires almost the entire time.
For street/highway, or mild off-road use, this combo will work. But, more extreme 4 wheeling will show the limitations of this suspension; I plan on cutting-out the rear fenderwells on my FJ40 this winter to prevent tire rub when the suspension is fully compressed.
Regarding wheel back spacing, 3.5 inch is the factory standard. Most of the aftermarket wheels with the correct bolt pattern are really "Chevy/GM" wheels, and have 4.0 inch backspacing.
Regards,
Alan
I picked up a set of Eagle Alloy's (3.5 backspace) and wraped them with BF Muders. still trying to work out the lift. I think I am looking at the BDS or the Skyjacker 4" with the Man A Fre schackle reverse just because of the shipping cost from Cal.
