howdy all any help on this would be greatly appreciated.I recently replaced a 74 302 with a 76 302 out of a mustang II. I put my original intake on the new motor intake was a 85 cobra intake aluminum 4 barrel set up. the motor doesnt seem quite right running wise. its missing and was making some unusual noises. a whoop whoop noise coming from valve train sound like from number three intake/ exhaust valves.upon closer inspection of new motors original intake (two barrel) i noticed that the rear two waterjackets are not there! Well... on my original 4 bbl. intake , they are there. my question is, could this be screwing up the new motor?to make the four bbl. application work , do i need to change the heads , or should i use the two bbl. intake and motorcraft 2100 carb. and if i do change the heads, are the 74 & 76 blocks the same to accept the water coming from the intake and heads? thanks in advance and of course
