3 speed transfer to 4 speed tranny conversion
NE PA coal region
Selling the parts to enable you to put a three speed transfer case behind your 4 speed transmission. All parts came from a complete 74 FJ40 donor vehicle. Included is the complete transfer case shift assembly, the transfer case front output nose cone, and the "transition" gear with the correct number of teeth and the right spline. Will throw in the used tranny output shaft bearings, too.
These nose cones are hard to find and this setup should give you everything you need to get the lower gearing the three speed transfer provides in LO range. Since this is a factory setup (used only in 74) the parts you need are here and right. Price for all the above $155 plus shipping. I can include the transfer case complete for an additional $130, keep in mind that the 1974 model was the strongest three speed transfer case Toyota made. I run this transfer case behind the four speed in my FJ55 and it is a great combination.
Can ship with/without the transfer case UPS without a problem. Private message OK, email is best- shmukter@pa.metrocast.net. Cut and paste the address as it is correct. Located northeast PA. Gary S
