didn't realise that the red bar was panhard. for what it is worth the radius arm design now becomes a complete waste of time and effort. will be much better off usiing a 3-link for the front and rear.
Why?
You are all over the place.
That Z link is just fine in the front.
You talk like 4 links are a piece of cake but now want a 3 link ( wishbone, true???) which will most likely need a panhard bar as well (if that is the killer I am super confused)...
What are you trying to do?
You realize that the only reason TG uses a three link on a mini is because the fuel tank gets in the way of a 4 link..
If 4 links are so easy, then do one. You are wasting your time on trying to be "novel".
weight savings on suspention = bad idea. Make that **** strong
PS building a 4link that works well is not "easy"
you are missing a key dimension that tells me it is strong![]()
I am still trying to figure out why you would do a true three link (with a panhard) on the rear of a truck.
2" x .500 wall uppers would be an unbelievable waste...
I am no quite sure why I am going to do a true 3-link in the rear of my truck.
@ th moment I am thinking that because I am going custom and I am only trying to build something reliable and simple I will go with the 3-link. 3-links are appealing because they are simple (and even though that may sound lke an understatement, it is true).
By utilising a panhard it means I can have parrellel upper and lower links. This gives me more room for a chassis tool box like I am already experimenting with:
The parrelel links can also be identical lengths and thus helping in carrying on-trail spares.![]()
