3" lift and 33 x 10.5 BFG AT/KO (pict)
Specific details on the lift:
OME - Med 2.5 springs
OME shocks
OME - stearing stablizer and new arm (mine were shot)
Poly pro bushings all the way around
Extra long sway bar links
3% caster shims in front
New u-bolts
Steel braded brake lines
Grease able spring pins & shackles.
sweet! looks like a real truck now ;)
-db-
mpetersrx7 said:
I thought OME shackles are 3" in front and 3.5" in rear.
Yeah I have the 589 seris which look very close to those.
Mark
Just measured them on my truck - 3-1/4" on the front and 3-1/2" on the rear as delivered from OME.
Overhanger...
I mesured the shackles:
Front were approx 7" long and 4" wide
Rear were approx 5.5" long and 3.5" wide
This measurement was taken from the outer edge of the shackle and not from the center of the bolts.
Did i measure them right? Or is there another way to mesure them.? :)
Good lookin rig dude, same color as the mudcrzr.
Same basic wheel as my Trail Ready beed locks.
Steve,
Are the longer shackles up front detrimental to anything?
Aseif007 said:
Steve,
When I first installed the OMEs a few years back, I mentioned the nose down stance on the 3FE list and Henry C pointed out that the longer shackles were in the rear and helped create the ass-end up look when the truck cargo area is empty. When loaded the truck stance evens out. If Mark's truck sits level now when empty, it will probably sag in the rear if the rear shackles are shorter than the front. Depends on what you like.
Mine were like the ones you run, I thought that maybe I could get a little more lift in the front, but I like the slightly raked look.
Hey guys...the truck sits very level. Iam not sure why Edwin put thoses shacles on.
I measured the rear shackles - they look the same but smaller - 3.5 mesurement between the bolts.
Iam going to see him next week to have some work done on the truck - I'll ask him.
