3/4 tub
Orcas Island, WA
Anybody replace the back 3/4 of their tub? How long did it take? My four day weekend just changed to a 2 day weekend. I was planning on replacing my tub from the front door jams back with a different tub I have on hand. Is two days enough to get it done?
Hi All:
"Beav," I did a rear frame repair and 3/4 body swap over about 18 months time.
Now, I was pretty busy with attending the University, working, exercising the dog, and maintaining the domestic harmony! :D
I was on a strict budget, so worked around other folk's schedules to get low-cost/free work done on the project. I would spend large amounts of time working the rig for very short periods! ;)
I finally got *most* of the project finished last June, just in time for an extended weekend 'wheeling/camping trip!
Although I suppose it is technically possible to do a rear 3/4s body tub swap in two days, if you are unfamiliar with the process, and are working on a rig that is an unknown entity, I think you'll be in for far more than two days worth of work!
Best of luck with the project!
Alan
What do you consider 'done'?
Set back on and attached to the frame or a running driving truck?
You will likely get the old one removed and the new one set in place, but I doubt that you will be putting the gas tank and seats back in it....
But who knows.....everyone has a different standard for what " works ".
Take a lot of pics and post some up!
Good luck!
-Steve
I think it's enough, if you have a little help centering everything and making sure it's level, one other guy would be helpful, I replaced the rear sill and rear quarters in a weekend by my self, a half tub in one piece shouldn't be too bad if it's straight and the front is as well, cheers, Larry
