I know many have inquired, and threads are out there on this topic, but I can't seem to get concrete answers on the line of thought I have on tackling this project... I'm sure there are enough Toyota technically inclined members here on 'Mud to help me figure this out...
The F engine in my '71 is toast and in need of a rebuild, I was going to restore the truck to stock but now I'm contemplating a Toy V8 swap, mated to a H55F. Lifting the hood of a 40 to find a modern Toyota V8 would be super cool to say the least. I'm now luke-warm on keeping the F engine and 3 speed tranny if I'm going to go through the trouble of a full restoration.
I'm surprised that this Cruiser engine swap is not more common since the 1UZ/2UZ-FE engines are reasonably priced and very available, but there seems to be little info out there on the topic of this swap with a manual transmission.
As far as I can tell, most 1UZ-FE or 2UZ-FE swaps that have been done with Cruisers have used an auto tranny, this makes it easier since the ECU in these engines also runs the auto. As far as I can tell the only Toyota ECU that will run a 1UZ-FE is an early Toyota Crown ECU since in these cars the auto transmission had its own stand alone ECU. The engine ECU will run the engine and not care what transmission you bolt up to it. There is quite a bit of info out there on making a 1UZ-FE work with a Toyota manual gearbox because 1UZ-FE swaps are common, especially in North America with Supra owners. I believe Castlemain Rod Shop in Australia makes bell housing conversions to make "R" and "H" series transmissions work with the 1UZ-FE.
Ideally, I would think that the 2UZ-FE would be a better choice for a Land Cruiser since it produces more torque much sooner. For some reason there is little info on doing a swap into a Land Cruiser with a manual transmission. From what I've read getting a 2UZ-FE to work without the auto transmission behind it is difficult; the later VVT and "drive by wire throttle" is another problem area as well from what I can tell. I doubt a 1UZ-FE Crown ECU would run a 2UZ-FE so I would think that the best bet is to run an aftermarket ECU, which means tuning it because no one, i.e. AEM seems to offer a pre-programmed "plug and play" ecu for the 2UZ-FE. An aftermarket ECU means tuning it and I don't think that there is anyone near me that would be familiar with tuning a 2UZ-FE, though I could give it a go myself I suppose.
The other option for getting a stock ECU to work with a 2UZ-FE that I've heard is to jump the park/neutral pins to fool the ECU into thinking that the transmission is in park. I haven't heard of anyone doing this, so if someone out there knows if this works, I'd be greatful to hear confirmation.
As far as getting a manual transmission to work with a 2UZ-FE any bell housing that bolts up to a 1UZ-FE should work with the 2UZ-FE, I think the pattern is the same. I know Lextreme.com offers a hybrid 1UZ/2UZ-FE that uses a 2UZ-FE block and they claim that it is a straight drop-in for an existing 1UZ-FE conversion.
Before I start buying parts I'd like to get some of these questions answered... anyone out there in Cruiser Land with modern V8 Toyota swap experience able to chime in?
