2UZ + A442F?
Zjohnsonua
Huntsville, Alabama
This question came up over beers between a few of us and I was curious enough to give it a search. I didn't find much that ended definitively.
The logic we had was that the FZJ80's 1FZ got the A442F and the A343F, and the 100's 2UZ got the A343F and the A750F, so there should be a common bell-housing pattern denominator in the 343. What prevents a Tundra's 2UZ and ECM from running with an A442F if the 343's BH is used? Will the 343's BH not work?
The 1FZ bell and flex plate would need to be used. You’d have to look at trans wiring specifically. Biggest issue I’d need to lookup. Is pwm solenoids in each. Line pressure is controlled by one so the programming might be off on that. The 100 A343f might have some extra sensors. But maybe not.
I’m parting 2 100 and have engines and parts including a a750f on the shelf, for a rainy day after winning the lotto... and have swap knowledge with my 80 with a Cummins running a stand-alone controller on a a343f trans that I did all the wiring and tuning.
I'll get into the wiring over down-time today. I'm surprised by the 1FZ bh suggestion for the 2UZ given that the UZ's starter is up top - I didn't figure it would clear... More HW for me to do it seems.
sorry wasn’t thinking clearly no stock bellhousing would work. A343f and a442f trans has a very different pattern. I was thinking other way. 1fz with 100series trans. I have a 442 bell housing and 2uz bell housing on the floor of the basement I collected years ago for my rainy day project.
Sorry for the miss direct.
Pics 442 is larger. Smaller is 750 but you get the idea. Engine side is the same. Trans side is a little different
I changed my search tactic and found these:
The issue seems to be the move from 3xx to 4xx cases since the US-market UZ never got a 4xx case. Makes sense, but sucks to discover. 35111-60110 shows available from Amayama with delivery expected in 4-12 weeks for nearly $600. It's good to know that the part is available, but that's a bridge too far for me.
