2nd ventilation hose leaks
Hi everyone.
I have a porblem in 4500 efi.
1fzfe engine 24v. The upper hose is leaking oil ,although I have replaced it 2 days ago. I also checked the ventilation valve and hose and it is good.
What can I do to stop it?
Many thanks
The photo is attatched.
First of all, this hose is set up differently than what I am used to here in North America. Could you provide a picture of the top of the engine for us?
Secondly, the hose clamps in your picture are the spring type. Perhaps if you replaced them with the screw type you could get a better seal on the hose ends.
I hope this helps.
fgp971
Glgummycarbs
THANKS. but the leaks is from the other side of the hose.
Bigaxejack
Thanks. I should replace the clamps to another type with a screw.
Here is a picture of what I have
It is fzj100 but the engine is 1fzfe with full electric coils.
Ok, I see. This must be a later model 1FZ-FE with the coil pack ignition and a different intake manifold from our 80 series. Thanks for the picture, I always enjoy seeing different set-ups in other parts of the world. Hopefully the screw-type hose clamp will solve your oil leak. If that's the only oil leak you have on your 1FZ, consider yourself lucky!
