2nd row seat bracket removal..
Bellaire, Michigan
I'm considering removing the 2nd row seat brackets...the part the attaches to the floor of the vehicle (after the seats have been removed).
Question: Is it just the one bolt holding that part to the floor of the vehicle? Before I start cutting the carpet unnecessarily, I wanted to make sure.
Thanks!!
There are 2 bolts, one is visible at the rear of the rectangular cutout, and another on the forward
slope of the floor. You will have to cut about 2 inches forward in the middle of the opening to be
able to get a wrench on the bolt. You can see in the photo that once you have removed the bracket
there is a barely noticeable cut line left. I plugged the holes with nylon plugs and silicone seal.
You can see the plug at the rear of the cutout. Once you have the 3 brackets out you will find
you have a large useable space.
