2nd generation ('94) sticky MIL
Malleus
contact@RESTORE4x4.com
Supporting Vendor
Charlotte, NC
I've had a persistent (in other words, I've done nothing about it) DTC 21 for some time, and today I finally decided to do something about it.
I pulled the right side (outer) sensor connection apart, cleaned it and tested the sensor. It's supposed to have between 5.0– and 6.5–ohms at 68°F. Mine had, well my DMM didn't see anything, so I guess nothing. Or infinite. Or something like that.
Anyway, I pulled the EFI Main fuse and went around cleaning various dirty needful items in the engine compartment, while I waited for the capacitor(s) to drain. I reinstalled the fuse after a goodly amount of time, inserted my handy–dandy check wire into the DLC1 connector and turned the key on. The MIL flashed "2" and "1", so I was confused. And am.
Now, to be fair, I haven't run through the entire road test procedure to check that the circuit is capable of checking itself (see page EG-226, if you're following along at home), but I expected that the error would be cleared and that I'd need to run the "two–trip" test to get it back on, since I am pretty certain the sensor is dead.
Any thoughts from the group as to why the code wouldn't clear?
Also, in an unrelated, or maybe it is related, thought, given the recent crop of previously unavailable parts, I thought I'd check to see if there was a substitute for the long gone 2nd generation O2 sensor (89465-69065). I was hoping against hope that I wouldn't have to install the 3rd generation O2 sensor and repin a new 3rd generation connector housing onto my 2nd generation harness.
Sure enough, 89465-69115 pops up and claims to be a replacement, at least for the right hand side sensor. Thought I'd add that tidbit to the mix.
Sorry gang, that was a poorly worded retelling of my afternoon. The service manual says that a DTC 21 is normal, with the check wire installed:
That wasn't really the point of my question/post.
What I was trying to get at was that the MIL did not go out after I removed the check wire and restarted the engine, as I expected.
FWIW, Dave sent me a pair of 89465-69115 O2 Sensors and I can confirm they fit a work in both positions.
I was reluctant to change the inboard O2 Sensor as it seemed fine per the FSM tests and I could not get to the thing. When we got to the Colorado Emissions Test a technician suggested it was not as good as the FSM suggested. A shop put the second 89465-69115 in and it passed with flying colors.
I guesss I'm the only one...I hate it when that happens.
